So, gettin pissed here. Can't OC my CPU so I decided to tackle AMDGPU again. Shouldn't be too bad, I would think. However I seem to be in an odd predicament when trying to install the -PRO driver where it wants to remove mhwd and, obviously, it cuts off. Its the package from the AUR as well.
I would use the normal AMDGPU driver if I could. Gimme a sec and I'll get a screenshot for you.
EDIT
Most FPS is at the main menu.
Looking straight up gives me 40. 2 months ago I got 80 and that was fine. Now it tanks. 145-160 in windows but I'm tired of its shit. I still have the 15.12 catalyst driver.
Youd need to remove all that crap and install the amdgpu-pro driver. you shouldn't be getting a black screen though with the normal driver.
fyi, you probably cant use amdgpu-pro, it doesnt support GCN 1. You might have support with kernel 4.8 but you probably want to fix that black screen problem first.
the screenshots are catalyst right? so not the same as radeon/amdgpu which have better support as far as i know.
On a positive note I can drop to terminal this time. However I don't know what to do from here aside from dig around in journalctl and get told I'm fucked.
They were cleared 2 days after they were made Doesn't matter anymore the mobo in that system is dead. I have a laptop and dual irwindale xeon system now. I don't think I'll be concerned on AMDGPU any time soon. Thanks though.
What was happening was the stuff would get recognized but as soon as the system made a call for the DE to render the screens would be deleted. I've fixed that before but I couldn't remember how. Again, doesn't matter now.
