AMD Versal Tech
Anybody seen this tech from AMD ?
What would be the use case for something like this other than in the Datacenter ?
Since it also seems to have Networking on Chip, is this using some Pensando tech as well ?
Maybe this is AMD’s version of a DPU solution ?
FPGAs have been around a long time and still have their use cases. Often times they did used to be used in larger networking hardware, but that is a lot less common now days with big powerful chips from Broadcom, Marvell, etc. Looks like AMD is hoping to try and grab some of that userbase back with this newer line of FPGAs again. Honestly less and less are using those type of chips now days because more and more and getting into ASIC design and that has become cheaper. Anyone that can afford a modern high end FPGA can also afford to design an ASIC now so :man_shrugging: You do still see FPGAs in a lot of automotive and industrial areas though.
