I have an AMD 8320 with the stock cooler, as you may know they have 2 locking metal arms which have to go around 2 small plastic arms on the motherboard. I can get 1 arm around 1 plastic arm but the other cant reach. Any suggestions to help fix this?;(
what i suggest you to do, is to buy an aftermarket cooler for the cpu, unless you can deal with the stock cooler to sound like a hair dryer... a 30$ CM evo 212 series cooler will be almost silent, and give you LOADS better cooling performance than the stock. And cooler operation means longer lifespan
You have to put a somewhat near a wrenching amount of pressure onto it... ran into the same problem on my first build and thought it wasn't manufactured properly.
