I’ve had an AMD Epyc Genoa system for a while now, and while it generally works fine, I’m not very satisfied with the CPU cooler, the Dynatron J12. It’s way too loud.
I looked into the Arctic 4U-M, but it seems the version for the SP5 socket was never released. Has anyone tried using the SP6 version on an SP5 socket?
Does anyone have recommendations for a better air cooler? I don’t like water coolers at all, but I would consider a 280mm model if necessary.
The Arctic 4U-M is a silent cooler and works well, but I use it on SP3 and can’t help you with SP5.
Just checked and it is advertised for SP3 and SP6 but not SP5 and it seems there are only server class cooler available for SP5 around here as well. Dynatron and the likes from Supermicro, but all small high RPM fans that will be loud.
What’s the power consumption of your CPU? I’m using a Coolserver single tower cooler with the included dual 120mm fans. I’m quite happy with its performance, with fans at around 65% and during 20 mins of Cinebench on a Epyc 9334 QS (210W TDP), the CPU never crossed 55 degrees. Mind you my ambient temperature is around 27 degrees. The fans are also quiet, dare I say imperceptible despite the cooler being used in an open mining rack.
The model I’m using can be found on Aliexpress here, but I can’t vouch for that seller as I got mine from Taobao.
Like jerro said, you have to choose your cooler base on your CPU. The cooler jerro use for his EPYC 9334 QS work really fine but it not enough for a EPYC 9564. On aliexpress you can fine different cooler. What is your EPYC cpu ?
If thermals aren’t a huge problem just swap the fan on your current cooler to a quieter model. I put a Noctua over an Epyc 7313 on the existing cooler and it hasn’t had thermal issues
