I have an XFX R9 280x and I was wondering if there are any waterblocks that fit it. I found this one:http://www.frozencpu.com/products/19248/ex-blc-1426/EK_ASUS_Radeon_R9-280X_Matrix_VGA_Liquid_Cooling_Block_-_Acetal_Nickel_EK-FC_R9-280X_Matrix_-_AcetalNickel.html?tl=g57c599s2074 But it says its for the Asus card will it work with mine as well?
XFX use a custom pcb for that card so no it wont fit. Your options are a universal block or say an AIO with g10 bracket.
If watercooling its always best to grab reference design cards to maximise fullcover waterblock options.
Okay. I guess that I'll just save up for a 290.
