Looking true old GPU to bay i so a HP AMD PRO WX 7100 for 120£
Gpu is only one slot and acording to multiple pages 10% slower then a AMD RX 580 8Gb.
Installed the card in a Dell T7610 and works no problem initialy, until i got to starting some games on it and found fast it was overhiting.
Given 1-3 min and it would get to 95c and shut down the GPU.
Did some investigation and there are 2 vBIOS for this GPU one called OLD one NEw acording to Toms Hardware.
Using GPU-z got my version backed up. and compared to the DB online and foun what i head was vBIOS 2017 and there was a new vBIOS 2018.
Started some testing GPU gets to 93c after 6-8 min and still crashed
So looked in to the fan and by default it will not go higer then 50% so found a software to coontrol it and make a nice Fan curve.
And now with a new Fan Curve max GPU tem was 81c and Fan went up to 3800 rpm or around ~75% Fan speed.
So for any one that has simila problem you cna trye ani of this
Software used to fix the problem:
gpu-z 2.55.0
amdvflash v.5.0.567
Fan Control V172
