Tested on a 10.15.7 MacOS VM with a 5700 and I get the following:
[ 50.259828] vfio-pci 0000:06:00.0: AMD_NAVI10: version 1.1
[ 50.259830] vfio-pci 0000:06:00.0: AMD_NAVI10: performing pre-reset
[ 50.259899] vfio-pci 0000:06:00.0: AMD_NAVI10: performing reset
[ 50.260407] vendor-reset-drm: invalid ip discovery binary signature
[ 50.260443] vendor-reset-drm: amdgpu_discovery_init failed
[ 50.260464] vfio-pci 0000:06:00.0: AMD_NAVI10: amdgpu_discovery_reg_base_init failed, using legacy method
[ 50.359814] ATOM BIOS: 113-D1820201-101
[ 50.359815] vendor-reset-drm: atomfirmware: bios_scratch_reg_offset initialized to 4c
[ 50.517819] vfio-pci 0000:06:00.0: AMD_NAVI10: bus reset disabled? yes
[ 50.517823] vfio-pci 0000:06:00.0: AMD_NAVI10: SMU response reg: 0, sol reg: 0, mp1 intr enabled? no, bl ready? yes
[ 50.517825] vfio-pci 0000:06:00.0: AMD_NAVI10: performing post-reset
[ 50.534546] vfio-pci 0000:06:00.0: AMD_NAVI10: reset result = 0
[ 72.163011] vfio-pci 0000:00:1a.0: enabling device (0000 -> 0002)
[ 72.268032] vfio-pci 0000:00:1a.0: vfio_cap_init: hiding cap 0xa@0x58
[ 72.368076] vfio-pci 0000:06:00.0: enabling device (0400 -> 0403)
[ 72.368170] vfio-pci 0000:06:00.0: AMD_NAVI10: version 1.1
[ 72.368172] vfio-pci 0000:06:00.0: AMD_NAVI10: performing pre-reset
[ 72.368235] vfio-pci 0000:06:00.0: AMD_NAVI10: performing reset
[ 72.368731] vendor-reset-drm: invalid ip discovery binary signature
[ 72.368768] vendor-reset-drm: amdgpu_discovery_init failed
[ 72.368789] vfio-pci 0000:06:00.0: AMD_NAVI10: amdgpu_discovery_reg_base_init failed, using legacy method
[ 72.465046] ATOM BIOS: 113-D1820201-101
[ 72.465048] vendor-reset-drm: atomfirmware: bios_scratch_reg_offset initialized to 4c
[ 72.622660] vfio-pci 0000:06:00.0: AMD_NAVI10: bus reset disabled? yes
[ 72.622670] vfio-pci 0000:06:00.0: AMD_NAVI10: SMU response reg: 0, sol reg: 0, mp1 intr enabled? no, bl ready? yes
[ 72.622680] vfio-pci 0000:06:00.0: AMD_NAVI10: performing post-reset
[ 72.640422] vfio-pci 0000:06:00.0: AMD_NAVI10: reset result = 0
[ 72.640528] vfio-pci 0000:06:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
[ 72.640536] vfio-pci 0000:06:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
[ 72.640539] vfio-pci 0000:06:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
[ 72.640541] vfio-pci 0000:06:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
[ 72.640543] vfio-pci 0000:06:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
[ 72.804716] vfio-pci 0000:06:00.0: AMD_NAVI10: version 1.1
[ 72.804718] vfio-pci 0000:06:00.0: AMD_NAVI10: performing pre-reset
[ 72.804793] vfio-pci 0000:06:00.0: AMD_NAVI10: performing reset
[ 72.805305] vendor-reset-drm: invalid ip discovery binary signature
[ 72.805363] vendor-reset-drm: amdgpu_discovery_init failed
[ 72.805384] vfio-pci 0000:06:00.0: AMD_NAVI10: amdgpu_discovery_reg_base_init failed, using legacy method
[ 72.900822] ATOM BIOS: 113-D1820201-101
[ 72.900825] vendor-reset-drm: atomfirmware: bios_scratch_reg_offset initialized to 4c
[ 73.059124] vfio-pci 0000:06:00.0: AMD_NAVI10: bus reset disabled? yes
[ 73.059134] vfio-pci 0000:06:00.0: AMD_NAVI10: SMU response reg: 0, sol reg: 0, mp1 intr enabled? no, bl ready? yes
[ 73.059136] vfio-pci 0000:06:00.0: AMD_NAVI10: performing post-reset
[ 73.076993] vfio-pci 0000:06:00.0: AMD_NAVI10: reset result = 0
Hereās the info of my card:
06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 (rev c4) (prog-if 00 [VGA controller])
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 118
NUMA node: 0
Region 0: Memory at a0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at b0000000 (64-bit, prefetchable) [size=2M]
Region 4: I/O ports at 7000 [size=256]
Region 5: Memory at bf600000 (32-bit, non-prefetchable) [size=512K]
Expansion ROM at bf680000 [disabled] [size=128K]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [64] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed unknown, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed unknown, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: Unknown, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00cd8 Data: 0000
Capabilities: [100 v1] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [150 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [200 v1] #15
Capabilities: [240 v1] Power Budgeting <?>
Capabilities: [270 v1] #19
Capabilities: [2a0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [2b0 v1] Address Translation Service (ATS)
ATSCap: Invalidate Queue Depth: 00
ATSCtl: Enable+, Smallest Translation Unit: 00
Capabilities: [2c0 v1] Page Request Interface (PRI)
PRICtl: Enable- Reset-
PRISta: RF- UPRGI- Stopped+
Page Request Capacity: 00000100, Page Request Allocation: 00000000
Capabilities: [2d0 v1] Process Address Space ID (PASID)
PASIDCap: Exec+ Priv+, Max PASID Width: 10
PASIDCtl: Enable- Exec- Priv-
Capabilities: [320 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [400 v1] #25
Capabilities: [410 v1] #26
Capabilities: [440 v1] #27
Kernel driver in use: vfio-pci
Kernel modules: amdgpu
06:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin B routed to IRQ 117
NUMA node: 0
Region 0: Memory at bf6a0000 (32-bit, non-prefetchable) [size=16K]
Status: D0 NoSoftRst+ PME-Enable+ DSel=0 DScale=0 PME+
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Address: 00000000fee00cb8 Data: 0000
Kernel modules: snd_hda_intel
