I need to know whether I should choose an AMD CPU or an Intel CPU for a $600 build. I'm pretty sure the answer is AMD but I need to know which exact CPU to get. This is for GAMING.
update: I made a list. Give me feedback please.
http://pcpartpicker.com/p/zLBCqs
update again: http://pcpartpicker.com/p/qYz4wP
update 3: i changed it again. http://pcpartpicker.com/p/cqJKxr
AMD. I would go with an 8320 or 8350 if you can squeeze it in the budget, if your going higher end video card maybe a 6300, but i would try for the 8 cores! xD.I wouldn't go Intel for $600 build unless you can get at least a i5 K version, the CPU start at $220 for that i think.
