So I've been using an XFX R7850 in my desktop with no problems for a while now. Recently my home server (an old desktop with a GTX 9800GTX+ in it) had some major motherboard problems. I've since just moved all of my sever stuff to my desktop.
Anyways, to the point! I've put the GTX 9800GTX+ in the second PCI-e port of my Desktop so that I can use a third monitor without an active adapter on my 7850. I mostly just intended to use the 3rd monitor for web browsing and hardware monitoring with rainmeter, but I would like to know if it would be possible to use the Nvidia card to also work for PhysX while still using my AMD card for everything else, and if so, would this require a custom driver?
Or, if that is not possible, would it be possible to give a virtual machine full access to the Nvidia card? I've used Virtualbox and VMware player before and I don't recall an option in either for this type of setup, but I've also never used 2 cards in one PC before.
And just one last thing, The Nvidia drivers (both the one Windows installed by default and latest recommended) are telling me the display I'm using does not support 1440x900, the resolution I've been using with it for the past 2 1/2 years. I've actually used it with this card before at that resolution on my server.
Any info on the subject would be much appreciated. Thanks!
