AMD Never Settle Help
Hi. I ordered a r7 260x from amazon and they told me that they would email me a never settle code. I accidentally deleted the email and I'm wondering if anyone knows how to get it back. Thank you.
If it's gmail then it's just in your trash. Any email should just put whatever you delete into your trash can. Unless you deleted it a few days ago? Other than that, good luck trying to convince Amazon to give you another code, unless they can just re-send the original email with same code?
