need some help with a build that I am planning to do, I am planning to build a TrueNas AMD lower power Rack U1 server. firstly is this achievable, if so what do you recommend. if not what are the alternatives (Arm, AMD). not interested in Intel.
You can tweak Zen3 Ryzen like a 5600x to 45W TDP, possibly even lower. Depending on the chassis you can go with a standard consumer board or check AsRock Rack for their AM4 server boards. And depending on what you want (amount of DIMMs, 10GBit networking, drives, efficient PSU), you can land anywhere from 30-40W to 100W idle depending on your configuration. With low-power in mind, you don’t need to go crazy on the fans, so even in a 1U chassis, it will be rather quiet. But 2U will offer much more quiet low-profile aftermarket coolers and more front bays.
My own Ryzen 5900x (@65W TDP) with 128GB memory, 6x HDD, 2x NVMe, 2x SSD and a couple of NICs (4x1Gbit and 2x10GBit) sits at 85W idle and 120W full load. But it’s running not only storage, but multiple VMs and containers, so horsepower is more than you need for a simple NAS
My truenas box is a Ryzen 5-3400G in my old X470 Taichi board.
It does a few jails/vms just fine (32G of RAM).
A few things to be aware of with Ryzen on Truenas:
Disabling AMD Cool & Quiet, ERP-Ready and Global C-States is recommended - leaving them enabled in BIOS can cause stability problems in FreeNAS
Not Ryzen specific… but don’t upgrade to Truenas 13 yet if you plan to run VMs under Truenas. It breaks VNC console to them (I upgraded today to try fix some stability problems, turns out the RAM i installed picked up XMP profile which wasn’t stable)
But yes, in general a Ryzen APU (any of them really) is ideal for TrueNAS. You can get plenty of cores, cheap boards, good upgrade path if you need it later.
I’m not sure about fitting the gear in 1 rack unit however. No idea what boards, cases, etc. are available with suitable drive bays.
That is correct. With the exception of Ryzen Pro CPUs. But good luck finding those in retail. If you want ECC but no discrete GPU, there is still the option to get a board with IPMI, which offers basic server graphics.
Ryzen will be tough to stuff in a 1u. Have you researched coolers or 1u atx cases? Epyc might be a easier build for something like this. If you are willing to step out to a 3-4u then it is a different story.
Alternatively if you really want 1 RU and have the budget, DELL do a bunch of rack mount 1 RU systems with EPYC if you want to step up (I’ve got a stack of R6515s at work)
But yeah in general 1 RU = OEM rack mount stuff, building it DIY is more difficult due to lack of parts availability for that, Ryzen or not.
What is your plan for the NAS? Is it going to be just a file server? We don’t have a lot of information to work with.
It’s easy to tell you to buy an Athlon 3000G, 8 GB of RAM and call it a day, if you are able to disable the GPU in the UEFI, this thing will sip power and will be more than plenty powerful as a NAS alone. I’ve had hypervisors running lots of VMs on NAS (via NFS) running dual core Celerons with no HT and they were working fine.
Why do you want 1U specifically?
Do you already have a rack cabinet?
Are you aware that 1U may be a bit noisier than a 2U, even with Noctua fans?
What RAID level do you intend to use with how many disks?
Is your NAS going to be multi-purpose?
If so, how many VMs and how many containers will it run?
What kind of services will it run?
How many people will access those services concurrently?
Would you use software that would benefit from GPU acceleration?
If all you need is a file server and nothing else, an Odroid HC4 might just as well be a solution.
