Im currrntly building my PC and one of the clamps isnt long enough to hook onto the plastic nub
please help i dont know what im doing rong. im using the standard amd heatsink for x4 965
I've had the same problem with Asus M5A97 R2.0 and stock FX-8320 cooler.
You can either try to force it or just get an aftermarket cooler like Hyper 212 Evo.
Im using the m-atx version so that may be it
Sorted the problem thanks
