Amd fx8350 stock cooler?
So i got the parts for my first build yesterday,put it all together,installed windows and what not then went on to play some black ops 2.In a very short amount of time the when i checked the cpu temp in asrock extreme tuning utility it was around 50 degrees Celsius and the stock cooler fan at 4000 rpm or more.I live in Italy and its cold(no heat turned on yet)my room temp is around 15 C.
If my cpu (stock cooler)reaches 54 C now in the winter can the stock cooler keep the the temp at bay during the summer ??I looked around an it seems that the max temp allowed for the amd fx 8350 is 60C.Do i really need an aftermarket cooler?
asrock 990fx etreme 3
amd fx8350(stock cooler)
P.S. I do not intend to overclock and the noise from the stock cooler fan does not bother me!
I would advise spending 20-25 euros on a cheap CPU cooler for other reasons. Stock coolers are not reliable. The heat and noise will grow over time, and become much more unbearable.
You will see a very good improvement in temperatures and noise. I know that you are not concerned about this, but you can eliminate those problems with a cheap heatsink.
http://it.pcpartpicker.com/part/cooler-master-cpu-cooler-rrt418pkr1
I think this unit is acceptable. The prices of components in Italy are higher than I expected.
Thank you for you answer!I will more than likely take your advice since i don't want any issues.
You can use the stock cooler. But if you start to notice problems then do not hesitate to purchase something cheap - it will do a much better job. I'm not trying to panic you, but it is only a small cost. Better to be safe and not sorry.
Thanks!I was already reluctant to use the my pc in full load because of this issue and will get an aftermarket cooler!I am new to using amd cpu's so i assumed that the stock cooler would be ok but I've heard that amd chips tend to get hotter than the intel ones.
Thank you!
https://www.youtube.com/watch?v=aTsZ1UBJR9c
