So this is a fairly new build i built 2 months ago ( my first build) And i want to see what the cpu temps were like so i fired up core temp and openhardware monitor and i was getting some strange temps like 8 20 15 17 and really low temps and im like wut... the room is not even that cold how? So make sure everything was ok and to see how my 8350 was doing under my hyper 212 evo i fired up prime 95 and did a torture test under
In Place Large FFTs(Maximum heat power comsumption some ram tested)
So after a min and a half and stuff i hit like 45 which is fine and it didnt really move moving about 1 degree per min so at 5 mins it was 46-7 and but at 3:30 something interesting happened with core 6 as you can see
well i have the same setup but i use the stock cooler, so mines idleing warmer, anyway you have a failure on core 6. i used prime95 long time ago for an hour, and i did not had any core failures, but i did some settings in Ai tweaker, cpu core voltage from offset to manual mode, let everything on auto, and i disabled cool n quiet. so my cpu runs constantly at 4.1GHZ. the only thing i notice, is that your cpu runs at 4.3GHZ at 1.325V, mines is running at 1.368V maybe you can try to set the cpu core voltage to manual mode in the bios, and disable cool n quiet, look if the still get the core failure, on core 6.
oh shit i have a core failure on 6? what about 5 cause it showed the same message and what does that mean are they completly unfunctional and it said poissle hardware failure... oh shit
Do not worry about the FX series idle temps. AMD is known to have bad thermal sensors. My FX6350 idles around 6C or about 13less than ambient (It's lying to me)
I find that their thermal sensors are not accurate until 25%+ load.
I have the FX6350 which is basically a 8350 but without the two other cores. same arch and everything.
Prime is a violent program, have you tried using other programs to see if cores 5 and 6 do the same thing? If the problem is only in prime than there is probably no problem because no real world application will be able to recreate prime.
Ran the test for 1/2 an hour it was yes core 5 and 8 that failed this time core 6 was fine... idk at this point im going to take this other persons advice and use another program
ok been running the system stabilty test for 5 mins now seems fine.. although it says the cores selected are
Cpu #1 / Core#1
Cpu #1 / Core#2
Cpu #1 / Core#3
Cpu #1 / Core#4
Although in programs it says all the cores are on full load so not 2 sure about that anyway it's running im not sure if the core fails how im supposed to know maybe it pops up or something but idk ill see
