Hey guys
I have the gigabyte 970a-DS3 motherboard and currently have the fx-4350. However at Christmas I plan to upgrade my GPU to the new R9 280x so I did alot of research and turns out I will need a new cpu in order to not bottleneck. However my motherboard does not support the fx-8350 (http://bit.ly/17MovWq) so i thought I could go for the fx-8120 as it does support that and then I could just overclock it. However not only do I not really know how to overlock I dont know what kind of overclock I can achieve or if my motherboard could handle it. So in conclusion I would like to know if this is a good idea and what sort of overclock I can get, or if the cpu at stock(3.1ghz) would be fine for my new r9 280x.
If i were you i would get a new motherboard now and get a better cpu later.
Whats wrong with the current one?
The Fx-4350 is a pretty fast cpu, I would just keep using that. The Fx-8120 is a previous generation FX cpu, also that motherboard does not do well with the 8-core chips, I know this from experience.
The fx-4350 would bottleneck the shit out of an r9 280x though wouldnt it? Would it be okay with a 270x?
i'm not sure if it would really bottleneck that much, people are going insane with the "bottlenecking" thing lately
also, there is 2 reasons a board wouldn't support an 8320
1. no vishera support (but you have a 4350, so that's not it)
2. not good enough power delivery for an 8 core (then it wouldn't support a 8120 either)
Im thinking of just sticking with my current cpu and buying an R9 270x directcu II. From what I can tell that setup wont have any issues running the likes of BF4 on at least high with well above 30 fps
Just get a Phenom 1100t
They are equivalent to the FX 8150.
I dont have £300 to spend on a CPU :P
