Amd fx 6300 not performing as it should?
hello i build a amd pc and i took a window vista 32bit from a old shitty pc and put it in there and now window vista only see 2 core so is it posible that because of viste only showing 2 core that it not performing as it should
does the mobo need a firmware udate
i dont think so i bought everything bran new custum build
Well I know 32-bit operating systems have a RAM limitation, but I don't think they have a CPU limitation...
yaaah i know it weird the previus pc use to be a dual core and vista is seying as a dual core
it is worth checking the mobo website just make sure you have the latest bios, there is noramaly a download tool to help check what version you have
CORE PARKING ! DISABLE IT !
Like the install disk, or did you just pop the hdd in with it pre installed. lol
i just pop the hdd in whit it preinstall i trie it whit my window 7 pc that was on a quacore intel 2500K cpu and window only saw 4 core not more so i think is has to do whit the preinstall os right???
Yeah, thats what I was thinking. I think you need a legitimate copy of windows.....But I really dont know.
Oh, maby install linux onto a flash drive and boot from it and see what it reads?
yahh i tink i will try that or just install window i almost fix the instalation probleme whit window
WHY DO YOU FUCKING HAVE VISTA?!?!?!?!?!?!?!?!?!?! Upgrade to windows 7 if you can. Windows 7 runs a lot better then vista, also make sure the bios is up to date. Would also help if we had specs
Ok, I'm sure you will figure it out.
i have vista becauz i install a extra hardrive tha contain a os that was vista in it i know vista is bad i was planning to install window 7 in it but im just having installing it i have a idea what the probleme is and the iso is 3.89 and the usb is 3.81   so yaah that would make sence
