AMD Friendly PC Build?
Alright so today I just wanted to see if this AMD Gaming PC Build will work and I want to know your opinions about it too. So here are the Specs for thie AMD Build.
PC Case :  [URL=http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001]Corsair Obsidian Series 800D CC800DW Black Aluminum / Steel[/URL]
Motherboard : [URL=http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514]GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0[/URL]
CPU :  [URL=http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284]AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core[/URL]
Memory/RAM : [URL=http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314]G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600[/URL]
Power Supply :  [URL=http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010]CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready[/URL]
CPU Cooler :  NZXT Kraken X60 RL-KRX60-01 280mm
Storage : HDD : Seagate SV35 Series ST1000VX000 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5"
SSD : Kingston HyperX 3K SH103S3/240G 2.5" 240GB SATA III
Optical Drive : LITE-ON Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model iHDS118-04
Video Card :
 OS : Windows 7 Home or Pro
You guys can add stuff to this whether to replace one PC part with another PC and thing like that.But yeah is this build worth to build for Gaming PC
Think new AMD mobo's are set to release by march (not sure). Might be worth it to wait a couple months? other then that it all seems pretty solid :) I got the same ram and its awesome just wish I bought more then 8gb, lots of love for G.skill :P
But is this Build still nice and is it very effective or no?
