Hi
I was planning a new build (for when the shortages are over and DDR5 is here). I wanted it to run linux with a windows VM and gpu passthrough (I was thinking about an nvidia 3080 or similar), but also I wanted a lot of monitors on the linux side; for this last part, I was looking at the amd firepro w600, which says that it has 6xdisplay port outputs and each can do 4k60fps. Similar cards I have seen can do 3x4k60 OR 6x4k30.
Does anybody know if the w600 has the same limitations? Do you have any other recommendations for the system/build?
Thanks in advance
