AMD Cooler
Is the stock cooler on the AMD FX-8350 Decent or should i spend an extra $20 and get a Cooler Master Hyper 212 Plus?
The stock heatsink is good but if you want a quiter build go for the hyper 212 plus.Iit's worth it.
if you dont oc the stock cooler is enough if you oc then have to get a different cooler.
The stock cooler is terrible and loud; it is definitely worth 20 dollars for the 212+. Good for a 4.2-4.3gHz overclock, and can be much quieter.
