Amd Computer build for £360 Help
Hey, I'm planning on building a computer with the following specs. Are these any good and if not what would be recommended.
AMD Phenom II X4 965 Black Edition, S AM3, 3.4GHz, 8MB Cache, 125W, Retail
8GB (2x4GB) Corsair DDR3 Vengeance Jet Black, PC3-14900 (1866), Non-ECC, CAS 9-10-9-27, XMP, 1.50V
1GB XFX HD 6870 DD Cooled XXX, 4200MHz GDDR5, GPU 925MHz, 1120 Cores, EyeFinity, HDMI/ 2x mini DP/ 2x DVI
600W Corsair Builder Series CX CP-9020048-UK, 80 PLUS Bronze, SLI/CrossFire, EPS 12V, Quiet Fan, ATX, PSU
MSI 970A-G46, AMD 970, S AM3+, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 2.0 (x16), ATX
Any opinions and comments are apreciated! I'm new to pc building and this will be my first one.
With shipping it comes to £368 and my max budget is £400
The only thing i would change is the 6870 for a 7850, it is about 15 euros more then the 6870 and the performance in certain games is quite big. Here take a look at the fps results of the two cards, see if it is worth the extra 15 euros: http://www.anandtech.com/bench/Product/549?vs=540
Other then that, it is a solid system. Should do fairly well in games and it is a good build.
Thanks, I will probaly get a 7850 :)
