Puting this up in general discussion because Im not sure where to put it. I thought maybe GPU, but my topic is more about my monitors and there's no monitor forum that I know of.
Mods feel free to move it to where you deem appropiate.
So, I have 3 BenQ G2420HD monitors, eyefinity and all that.
Im looking at AMD CC and My digital flat-panels>HDTV support (digital Flat-panel):
HDTV Modes supported by this, lots of things in a small window that I can scroll through,
I want maximum HD and good image quality on my monitors, im just wondering what format I should apply/force
Is it 1080p24 format to the display manager (HD) or is it 1080p60 (NTSC) or 1080p50 (PAL) or 1080i30 (NTSC) or 1080i25 (PAL)
I don't even know what all these acronyms mean - NTSC and PAL.
which one do I add?
I read that im not supposed to touch these options if im not seeing any screen parts missing, like some parts of the resolution is not visible etc.
What im experiencing is however a clear delay when moving stuff around on my 3rd monitor, I thought it may be the HZ But when I checkt the properties on AMD CCC it sais all are set to 75hz, all monitors are plugd in with DVI to my GPU.
Help?
