i have to builds an amd and an intel. the intel is more cheaper but i think just for an extra $50 i will get better performance. both builds are for gaming, i live in australia so the currency is different so keep that in mind. i am also wondering which build will be more easy to upgrade. i know more about intel and their products so when its time to upgrade the amd build it might be hard for me. if i get the intel build im afraid it will be an expensive crap build but i can upgrade to an i5 in a few months. but im worried in those months before upgrading my pc will be bad for gaming.
intel build
Motherboard
Asrock Fatal1ty H87 Performance (LGA1150)
http://www.dcomponline.com.au/productview.asp?proid=8955
CPU
Intel Pentium G3220 3.0Ghz CPU (1150)
http://www.dcomponline.com.au/productview.asp?proid=9158
Graphics Card
Palit GF GTX650 2gb
http://www.dcomponline.com.au/productview.asp?proid=8933
RAM
Kingston DDR3-1600 4GB
http://www.dcomponline.com.au/productview.asp?proid=8854
amd build
CPU
AMD FX 6300 AM3+ CPU $169
http://www.dcomponline.com.au/productview.asp?proid=9109
Motherboard
Asrock 980DE3-U3S3 M/B $75
http://www.dcomponline.com.au/productview.asp?proid=9169
Graphics Card
Sapphire HD7790 2gb OC Version $169
http://www.dcomponline.com.au/productview.asp?proid=8881
RAM
Kingston DDR3-1600 4GB $55
Computer Case
Cougar Solution 67M3 500W Midi Case $89
http://www.dcomponline.com.au/productview.asp?proid=8993
AMD.
At this low end stuff/budget, AMD will do much better. The FX-6300 is still quite a capable CPU.
ok thanks what about when i need to upgrade? and can amd run ac3? also do you have a nice $550 aud intel build and pls use the website that i used
http://www.dcomponline.com.au/productview.asp?proid=9134
is the intel i3 worth it for its price? remember its in aud
also is the intel i3 better than the amd fx 6300?
The FX-6300 is a great budget gaming CPU. It'll last you awhile. Upgrades you can do would be a better GPU, 4 more GBs of RAM, and a SSD.
what if instead of the intel pentium g3220 i replace that with an intel i3 4130 making the build about $600 aud will it beat the amd by performance and price?
Nope.
The Intel i3 is stronger in single core performance, but the FX-6300 will blow the thing out of the water in threaded applications. TBH, 2 cores isn't enough for gaming nowadays.
im just curious what is your build?
My build: http://pcpartpicker.com/p/2iyxk
First purchase:
CPU, MoBo, Case, RAM, HDD, PSU.
Second Purchase:
GPU, SSD, AIO, BlackWidow KB
Everything else I had already.
