AMD Athlon X4 750k help with temps
Hi! I finished my first build 2 days ago and when today i checked my cpu (AMD Athlon X4 750k @ 3,6Ghz) temps they were really odd. HWMonitor says i'm idling at ~50 C, and EasyTune6 (i have a gigabyte mobo) says ~20 C. And when running Geekbench 3 at full load on the cpu HWMonitor said my cpu temperature was ~95 C but EasyTune said it was only ~60 C. Which one should i believe? (I have a Thermalright True Spirit Rev a 90mm as my cpu cooler) What temps i should be getting?
I've never heard of EasyTune but it's probably the more accurate one. I don't know what temps the X4 is rated at, but if you're using the stock AMD cooler (which is a POS) you're probably idling at closer to 30C and at full load it might get up to ~70C (not sure about FM2 chips, just estimating based on experience with AM3+). Again, I don't know what it's rated at, so 95C might be safe with an FM2 chip, but I doubt it and it's more likely that it would throttle hard before it got that hot. I mean that's almost boiling. Try other software, too. Try speedfan and coretemp.
I tried speedfan but it only showed the clockspeeds and cpu usage. Coretemp couldn't detect my cpu at all. EasyTune came with the drivers for my motherboard and i feel like its showing about right temps. Also when i'm in the bios it seems to double the fan speed and temperature compared to EasyTune. (800rpm to 1600rpm and 20-25 C to 45-50 C) My case (Fractal Design Arc Mini) also has three fans and the wires aren't blocking the airflow. I think the mobo might be a little broken or i just need to update my bios?
Perhaps, although I really can't say. I don't know much about this as I've never had a problem with it. I'm going to guess that your temps are fine and that your mobo is at fault.
i use HWiNFO and it gives me accurate temps so far. it also might depend on the mobo as well.
what motherboard do you have?
