Amd apu build or intel help!
Skewt, I'd really go with the AMD build on this one.  First off, the 430W PSU is cutting it close on the Intel build.  Secondly, you're going to need a much more powerful CPU than a 2X2.6GHz Pentium in order to play the games you listed.  (See link below for A10 performance alone on BF3.)  Personally, I tend to fanboy intel/nVidia, but In this case, I'm seeing the AMD build as a much more cost effective and expandable build.  If you have $200 at a later time, you could throw in a 7770 or even a 7970 and boost your graphics performance incredibly.  The AMD build is overall better.  Just make sure you get the 1866 RAM because if you don't, your graphics will suffer.  (APU uses RAM for graphics portion, thus, a lower RAM speed will cause your performance to suffer.)
 Also, why get a microATX form motherboard and a mid-tower case?  Not too much of an issue, seeing how you're going to have lots of air flow, cable management and expansion room, but just curious.
EDIT: forgot link: http://www.youtube.com/watch?v=ijRbNnSuqxc
Print off the rebate form and mail it in with a proof of purchase date that is eligable.
so I purchase the item THEN mail in the rebate?
Yes. It'll take like a month before you get the money back.
I'm sure they do it to make interest on that bit of money. That way it doesn't hurt them to give that amount back. Tricky aren't they? lol
Hey guys is the A10  APU any good or should I spend the extra $100 and get a dedicated gpu, and does anyone now how good the A10 will perform in Crysis 3, DayZ, and BF3?
