Amd and 780 or Intel and 770?
Hello everyone! Thank you for taking the time to read my post :)
So i'm about to buy the parts for my future pc, but i'm not sure about something.
I don't know if i should get either the i7 4770k with an EVGA GTX 770 or the Amd 8350 with an EVGA GTX 780, they pretty much come up they same price, but wich one will be better?
Thank you for all the replies! Much appreciated
Might want to keep an eye on my post as its almost the same and expect the replies will be useful
https://teksyndicate.com/forum/build-pc/amd-fx-8350-or-intel-3570k-gaming/152590
It really depends what you're doing with your system.
If you're only gaming, you would only need an i5 for the Intel option.
Also, the 780 is kind of excessive. It is a little bit of a "niche" card, which is highly geared towards gaming at 1440p, or surround. If you're gaming at 1080p, I would recommend the 770, 7950, or even the 760.
