AMD am4 zen 2 3 Ryzen agesa 1.2.0.4 1.2.0.5 1.2.0.6
Since agesa 1200/1201 and the capping of boost override to +200 and the more mature curve optimizer progress was slow and small fixes until agesa 1203a/b/c. (Quite good?)
It now seems AMD is slowly working at fixing or reworking boost behavior (recalled and reinstated beta bioses and many skipped versions).
Agesa 1204 had a bug with vddp voltages being fixed at 1.0V no matter what you needed or set them to. This hardly left beta stage for most boards.
With agesa 1205 some things changed. Many people reported changed boosting behavior and having to retune earlier stable curve optimizer values.
Also if you play with PBO now if you set EDC over the stock 140A VID-requests are capped at 1.425V instead of 1.5V.
You can work around this by leaving EDC on auto in bios and changing it with RyzenMaster.
This leads to the question if this is a bug with the bios settings or an intended change and the RyzenMaster workaround is a bug.
For now I’d caution about testing the new betas if you have a problem free tuned system.
Also there are some reports that some of the changes to the boost behavior stays with the cpu even if you flash back to earlier agesa.
@wendell I know 12th gen is the new big thing but you may still run some OCed Ryzen rigs - got any insight?
This was on my radar, esp. the 1.425v thing.
That has been a thing for some time.
For my longer-term OC’d ryzen rigs I’ve had some quirrely problems here and there where the oc is stable/fine but then I have weirdness on pcie uptime or weirdness under linux, but not windows.
I have noticed newer bioses are much less aggressive but I have yet to murder a cpu.
I suspect the ryzen master work around is a bug.
Part of the issue here may also have to do with post behavior. I have some systems that are really touchy about posting, esp. cold post, with 3600/3800 memory (with tuned timings). When we have a power outage I leave it on for about 10 mins in a failed-post state, hit reset, it boots right up.
I’ve noticed on at least one system this behavior went away but the memory continues to work at the tighter timings with no other tuning. However the all core boot behavior is now slightly worse than before.
More fun 1205
Seems gigabyte misplaced max boost override instead of adding the + and - option MSI and ASUS added.
I’m currently having a good time with AGESA 1206B on an ASUS ProArt X570-CREATOR WIFI, seems to have fixed the S3 standby/sleep crashes I’ve had the pleasure with.
Additionally the used 5950X (early model from fall 2020) runs a bit cooler (Noctua D15S air cooler) and boosts to 5.000 instead of “only” 4.950 MHz under lightly-threaded load, not that it really matters.
Would this mean that the boosting bug on my S1 3900X would be fixed?
And stop cooking the universe requiring an underclock?
@FaunCB
Sorry I forgot replying to your question, I’ve been streched a bit thin due to having to plan a renovation.
In my experience with multiple AM4 CPUs since Ryzen 2000 (4C, 6C, 8C, 12C, 16C) that question cannot be easily answered:
  • Manufacturing tolerances even with the same SKU are quite noticeable: By that I mean the flatness of the heatspreader’s surface on top and the thermal interface between the heatspreader and the actual silcon parts internally; both variables influence the thermal characterisics of every single specimen significantly.
  • What helps a bit: When using a new CPU, torture it a bit with heat (I do 24 h prime95 runs to test new parts), the metal heatspreader changes its form a tiny bit during this process. Then remove the CPU heatsink, reapply thermal paste and reseat the heatsink.
  • Different motherboard manufacturers make a difference regarding boost behavior even with the same AGESA version.
Seems news is picking up traction.
How would I figure out though what AGESA version is in the BIOS?
Afaik the only clues for that are in the changelogs for the BIOS, but what if it’s not listed there?
That SMU checker is neat, mine is CastlePeakPI-SP3r3-1.0.0.4.
Guess ThreadRipper is not in that?
You can use CPU-Z, I believe it’s on the main board tab
Yes it is, I haven’t ran CPU-Z in forever, had to get a new version.
