AMD A4 4000 with an EVGA 750Ti will it work?
Cheers!!! :O)
Yes, just make sure you disable the integrated graphics in the bios and switch to pci-e as your primary graphics adapter.
Cheers cherryducks!!! :O)
I may be wrong but I remember reading somwhere that crossfire doesn't work very well with linux and the op said
so that would potentially be an issue.
The 750ti or an amd equivalent standalone gpu is propably a better choice.
Cheers for the info bigfil :O)
It will work but the GPU will be hopelessly bottlenecked by the APU. You would be far better off going for a high end APU with some reasonably fast ram then adding a GPU when you can afford more.
Cheers for the info @BulletCatcher77 :O)
