AMD A10-5800K build
Hi all,
I'm busy with a build for a friend of mine, we play a lot of leageu of legends together but right now he is using an ancient laptop so we plan to build a pc, what I'm going to build for him. It is my first time though and I would really apreciate your opinions and advice about this build. the budget is 400 to 550 euro, which with the european prices is in general the same budget in dollars.
note. he wants to use his pc on his tv so he doesn't need to buy a monitor its a pretty huge tv full hd we will use the hdmi connection on the motherboard so we can use that speakers as well.
This is my build:
CPU: amd 5800k: 110 euro: http://azerty.nl/0-5217-557801/amd-a-serie-a10-5800k-.html
Motherboard: 70 euro: http://azerty.nl/0-5213-557804/asrock-fm2a75-pro4-.html
RAM 8 GB: 60 euro: http://azerty.nl/0-3317-565767/kingston-hyperx-beast-.html
HDD 750GB: 62 euro http://azerty.nl/0-857-528525/wd-caviar-blue-wd7500azex-.html
SSD 64GB 70 euro: (we really want a ssd for the speedy experience: http://azerty.nl/0-1990-521128/ocz-agility-4-series-.html
DVD burner: 17 euro: http://azerty.nl/0-862-258095/liteon-ihas124-c-.html
PSU 430W: 42 euro: http://azerty.nl/0-1073-555971/corsair-builder-series-cx430-.html
Case(we liked the looks): 56 euro: http://azerty.nl/0-1044-394090/zalman-z9-plus-.html
with shipping this was about 500 euro.
I hope you can give me some opions or help.
looking forward to your reactions, sorry for my english we are from Holland :D
If I were you, I would wait for the next generation of APUs to come out next month. Also your RAM choice seems to be overkill, you could pay a few euros less for 1866 memory.
Thanks for your comment do you know the codename for this next gen apu's? Because we have the time waiting for it.
Richland
http://www.tomshardware.com/news/Richland-APU-iGPU-Clock-Speeds-Specs,20748.html
Thank you very much.
I would also wait for ricdhland if you can. It should be out in about 3 weeks.
However I think for an A10 I think you should get the fastest ram you can afford. The igpu benefits immensly from fast ram:
http://www.tomshardware.com/reviews/memory-bandwidth-scaling-trinity,3419.html
