AMD 7790 VS Geforce 650 ti boost VS Radeon 260X
I'm building a Budget Gaming PC and trying to settle on the most controversal part... The GPU. Ive been looking at 3 different ones in particular as mentioned in the Subject. They all fall within the same price range, Two AMD and One NVIDIA. now of those three which one would be considered the "best" or superior to the others. could someone give me some suggestions, or maybe suggest some better graphics cards, Thanks
(Btw could you give me how many Stream processors the GPUs have)
A 7790 is a 260x
260x vs 650ti boost --> http://www.anandtech.com/bench/product/1044?vs=1040
http://www.anandtech.com/bench/product/1044?vs=1035 A 260X is faster but yes it is a remake of the HD 7790 but obviously slightly more powerful. If you could get the money, go with the R9 270. A little bit more expensive than a 650 Ti but more powerful http://www.anandtech.com/bench/product/1043?vs=1040
Actually a lot more expensive. The prices have gone up on the Pitcairn chips to above $200 for the 270.
(that is for the US, other countries may differ)
