Amazon selling discontinued model with new model on same listing
I bought three trendnet switches 5 months ago. Two of which are revision 1 which are discontinued and defective. The third is revision 2 and works fine. Basically both of the version 1 models are maxing out at 300mbps even when running 10gbit or 2.5gbit. It can’t even hit 1gbit. The second revision achieves speeds at tested with iperf3. Amazon has the picture for revision 2 and sent out revision 1 which are completely different. One is like 4 inches bigger and two is tinier. I just don’t know what to do Trendnet refuses to send revision 2 and amazon wont replace my two that are defective. The revision 2 I see 9gbit/s for 10gbit line and 2.4 for 2.5gbit connection. Where as 1 says in windows it is 2.5 and 10 but maxes at 300mbps. The other issue is my macbook connected to the revision 1 model gets 10kbps where as revision two it gets a full 2.5gbps.
Sorry for poor grammar. I am just frustrated and have had network woes since I bought these, I just didn’t know exactly what was to blame. Now it is 5 months and amazon is still selling revision 1 and 2 in the same listing even though they are completely different things.
It seems my entire issues with these devices has caused my entire headache i have been trying to figure out for the better part of the last 4 months.
What the sigma
The link on my orders show revision 2, but they dont even look similar revision 1 and 2. And I ordered three of them at the time and didn’t think anything of it. But I finally started to use them and it struggles to go past 300mbps. It seems to be an issue with the revision of the model, either way trendnet wont replace it with revision 2 and amazon doesn’t even have a way to return it anymore.
What is weirder is it seems to be an issue between windows and the switch. When I do iperf3 -c ip I see 300mbps when i do iperf3 -c ip -R (reverse direction) I see 2.47gbps. This has been going one for 4 months or so.
Scamazon strikes again!
Got a link for people to blacklist?
Was the order shipped direct by the seller, or co-mingled with whatever defective returns amazon happened to have stocked at the time?
It was direct by Amazon. Shipped and sold by Amazon.
It is not good, but at least explains the fact the seller has no way to control what good / bad / version is shipped by Amazon
I’ve made similar mistakes (ordering X item and storing it away past return window) Amazon might actually give you a gift card if you’re clever enough to get to their live chat support
