I got an amazing deal on a 4564P from newegg for $275 shipped. I currently have a desktop with 3700x, Asrock b450m pro 4 and 64gb 3200 ram. I am going to use the opportunity to upgrade. I do some gaming and a decent amount of video editing as well. Here is my plan.
I know the cooler is a little under spec, but I can turn on eco mode on the CPU till I feel like I want the full multicore performance. I have an x570d4u nas that I use for most of my storage, and can use one of the wired x4 slots on the mobo for my nic. The other mobo I was looking at was the b650e riptide, but I would rather have the 2 x4 slots on the livemixer.
Black friday. It was posted on build a pc sales. Part of the reason I will go non ECC is amazon has the livemixer for $150 and newegg doesnt really have good prices on ecc ddr5. The cpu comes with a $100 giftcard to newegg that I will use for the ram. The total price was $375 for CPU and gift card.
Also don’t forget that nested virtualization random reset bug that AMD said they will only fix on the epyc 4004 processors and let ryzen 7000 series continue to suffer.
I think video editing will not care about 5200 ram. Gaming, I am already GPU bound at 1440p. So realistically outside of benchmarks I will not be able to tell. The boost clock is the same as 7950x. @twin_savage
Thanks, yeah I have a 5450g in my server and just passthough the GPU to my jellyfin LXC. Immich in my docker VM could use it but I don’t plan on trying to get around the reset bug just to save a bit of power on video transcoding in immich.
Wait just read your comment again. That is a good reason to keep the EPYC for my future server hand me down. Although so much can change in 5 years with that bug.
The reset bug was the VM causing the entire host to reboot without warning or log entries rather than the PCIe passthrough reset bug. It has to do with the VMLOAD/VMSAVE function not being “supported” on consumer CPUs. The Linux kernel tried to get around the issue but I hear there are still problems even after the latest urgent pull request for 6.12.
AMD is going to fix the issue in microcode, but only for the epyc CPUs.
I will take a look on newegg when my mobo ships end of december for ECC and let you know if there is anything. I would be fine at 32gb. Is 4 dimms still not advised or is that just consumer ryzen?
IF you ever plan on using this as a server later, buy the TPM module for the MoBo now and the RAM.
Registered ECC RAM goes down in value like the Titanic
But unbuffered ECC increases over time
forgot to mention: your CPU is not on the QVL for that board
You’ll want either an Asrock rack board or Supermicro for full compatibility
Again, get the TPM now and thank me later
I have to recycle servers at an average of 1 every week because the TPM modules are no longer available just 3 years later.
