Greetings all,
I am currently working on upgrading my compute server for my home lab. I am using proxmox as my hypervisor current set up is an amd 2700 and an old gpu just being used for video out. The goal is to eventually set up a windows vm for gaming that will be accessed via something like moonlight over the network. I do plant o run additional vms besides the just the windows machine for gaming such as jellyfin ect.
Current specs i’m planning
Upgrade cpu to either a r9 5900x or 5950x or 5900xt (5900xt doesn’t seem cost defective)
64 or 128 gb of ram
3080 or amd rx 6800/7700
Storage will be either local drives or a truenass box on the network
The goal would be to play games on the remote system (laptop )at 1440p at around 60-100fps. I have a fair bit of experience running vms but mostly for headless setups or just basic a basic desktop. Do the above parts seem capable of this? I have a feeling that my network will be the main hold up as im still running just 1g on a home router.
Thanks!
Yes, after the upgrades your system will be more than capable for the tasks you require.
Speaking from experience here: I would get a fast SSD and dedicate it to your gaming vm. You do NOT want the headache that I dealt with of running windows on a Zfs pool with 10+ other vms on it. You will find the system slow to a crawl. Especially game load times, and stutters as new textures are loaded in game.
The horsepower you plan to install will be more than enough to push 100 fps. But latency could have a huge impact on your enjoyment of the games you plan to play. Your 1gb of home internet is more than adequate for moonlight streaming. I have never gotten it above 150mbs even at 4k 120. If you plan on a client laptop, I would highly recommend wired connections both sides of your router/switch that connects them. Your going to be pushing such a large amount of data that any network inconsistencies will be very apparent.
I would very highly recommend parsec for remote usage of your VM. Moonlight is a great tool, but its bandwidth usage makes it impossible to use with limited network speeds. Not to mention the impacts of increased latency outside your network. Do not drop moonlight all-together. Moonlight is far superior for quality, features and performance. But parsec just handles latency and bitrate a lot better.
Thank you so much for that detailed response! Do you have any insight into the current state of GPU virtualization? My understanding is that Nvidia removed the block from their driver’s and amd works without an issue.
Currently there is no method for virtualization of your proposed 3080. Or any ampere generation besides the rtx a6000.
However, that isn’t a dealbreaker. vGPU is important when you have multiple guests that want a piece of the pie, or the gpu. In your case, you can just pass-through you card as one pcie device into your gaming vm. That breaks the restrictions on Nvidia Cards.
Unfortunately I do not have much of any experience with AMD cards and vGPU. I find that my nvidia m40 server gpu and even its first generation nvenc encoding is more than satisfactory. I get performance around a 1660, but with 12gb of vram, and the ability to encode 16 streams. This becomes important when pushing large bandwidth from a display to a remote machine.
Mainly, identifying the goals of the gpu would be important for making the correct choice. I’d say that if you are looking at multiple vms that are going to be in a deep learning curve quite quickly.
Again, do your research on what you are trying to accomplish!
@Dimple8 I think what you are referring to is an article that Btarunr wrote published by Tech Power UP @com
While it might be possible to use your current graphics card one day without passing it through to a virtual machine (vGPU), you would still have to pay what I call the “Nvidia tax.” The last time I looked into vGPU, the cost was $250 per running virtual machine. For example, if you had four virtual machines running and wanted to split your Nvidia 3080, your total cost would be $1,000 for using vGPU. I can’t remember if the total cost would be $1,000 yearly or monthly.
Thank you both for the information I should have been more specific I meant pass through rather than virtualized My current understanding is that both AMD and Nvidia GPUs are capable being passed through to one virtual machine without issue at this time
Nvidia will still give you code 43 if it detects it’s in a VM. Mask it in KVM settings and it works.
Jellyfin requires hardware acceleration and unless you have a 2nd, smaller GPU to pass to jellyfin, you’ll need vGPU support if you want to run the VMs at the same time.
jellyfin does not require hardware acceleration. Even the 2700 limited to 4 threads in a VM could handle lots of streaming and a couple 1080p transcode operations with out being a bottle neck. Anything from the 59xx series of CPU would be more than capable of software transcoding with maybe even 1 or 2 4k streams if the remainder of the environment was up to that task.
i was using 8 threads from a first gen RYZEN CPU with no issues streaming to a LOT of things and never maxed the CPU out. i only just recently even bothered adding a T1000 as a transcode card because i came across 1 for free.
Actually I’m running jellyfin on the current platform with a smaller GPU passed through for hardware transcoding .Good to know that Nvidia is still doing code 43s on VMs
Fair. But that’s kind of a waste, using GPU cycles for transcoding. Anyway, you’re correct.
It’s not like it’s impossible or even difficult for that matter to get rid of code 43. Just that you still need to trick the VM into thinking it’s bare metal.
Just waned to post a quick update all parts have been acquired and are running well took a bit of tweaking to get GPU pass through working, I had to disable ram bar in bios to get the 7700xt working consistently. Also proxmox has a bug where if my gaming vm crashes it auto restarts all the other vms. But over all its usable thanks all for the help and advice !
