Hi guys,
not really and AMD fan, but I thought let's try a build.
So I'm wondering which socket is more future proof:
AM3+ or FM2?
I'll be using the system for some light gaming, and light photo-editing
Thanks,
Andrew
Hi guys,
AM3+ or FM2?
Thanks,
Andrew
i think the best way for you will be a am3+ with a dedicated gpu. if you want things more future proof. for gaming. i think this will give you more performance.
i agree with ^ but for light gaming a a8 or a10 apu (fm2) would be fine as you can get the same graphics card that comes with it and it basically does like crossfire
FM2 won't be supported anymore from the next generation of APUs, and though no one really knows if Steamroller is going to have a AM3+ processor in its forms I think the latter would be a better choice for the future. But keep this in mind: both the platforms are getting quite old and I don't think AMD will support AM3+ for more than a year or 18 months...FM2+ is going to be supported though and it's backwards compatible with FM2, the new APUs are getting there and - I guess - some other kind of CPUs as well. New Athlon processors maybe? Anyone knows?
Lots of tests show that hybrid crossfire with iGPU and dedicated GPU doesn't work well...it's better getting a beefier dedicated gpu and running out of that. In all fairness, you can buy a FX-4350 and HD7850 and it'll destroy that a10.
Yep, unless you go for the HD6670 there is NO POINT in Crossfire. I was seriously considering an APU solution in a recent build but went for the FX-4350 + HD7850 too. It's just a pretty damn good bang for the buck.
Steamroller has been confirmed to be on FM2+, and right now there's only a few FM2+ mobos.
I can pretty much seeing AMD going the FM2+ route for a few years as their only socket.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007625%20600469846&IsNodeId=1&name=FM2%2b
