So i just bought a new motherboard to replace with one i already have which is the Asus M5a78l-m lx3. I am replacing it with an MSI 760GA-P43 (FX). The reason for this is that my current mobo does not support my cpu but the MSI one does (in it's CPU test list at least), i have been reading reviews on it and im getting some mixed answers, all i want to know is what do i have to do to get it going (i have an old fx 4100 if that helps) so basically im looking for a few answers:
1) how do i update the bios?
2) will i need to reinstall windows?
Please be friendly i have installed everything but a motherboard in my PC
did you allready buyed the motherboard?
Yes i bought the motherboard
well the cpu is supported with that mobo, you need to uninstall all drivers in device manager, download the latest drivers for the board from msi website. shut down system change the board, bootup, install drivers and you will be good to go. if you get a Bsod during booting, then you probably have to do a reinstall. Bios update is not needed but you could allways do it afterwards, with msi live update.
thanks, everyone else i asked was being a douchebag about but this was really good info thanks
According to ASUS your old board does support the FX 4100. Also both boards have the same NB & SB chipsets, even the audio chips are the same, so you should be able to drop the new board in without changing drivers at all. If you can return the new board I would suggest doing it as you aren't gaining anything.
no my old board doesnt support my 8320 but my new one does
