am3+ fx
Ok so I have a asus 7970 already and I just need everything else.  I am trying to stay around the 350 mark for the rest of the system.  Playing around myself I have gotten pretty close, but not quite there.  I am ok with some compromises like 4gb of ram, as I can upgrade that in the near future, and the same goes for a cpu heat sync.  Hopefully someone can get as close as possible to $350.  Cheers!
http://pcpartpicker.com/p/sw866h
I mad some tweaks to thecaveman's build to get a bit closer to $350 (I know this isn't your GPU but I wanted to get an idea of the power requirements).
http://pcpartpicker.com/p/z6x44D
The CPU might cause some bottlenecking, but I think it's something you can get away with:
https://www.youtube.com/watch?v=qIT9uLDjZcg
The other change I made was going to a single 8GB stick so you will have the ability to upgrade in the future.
Can't really lower the price that much :|
http://pcpartpicker.com/p/NJcJt6
I would prefer the FX-6300 over the 4300 and X4 760k, though.
+1 especialy with a 7970.
http://pcpartpicker.com/p/gyz223
fx-630
4gb ddr3 1600
source 210
xfx powersupply
cheap sea-gate hdd
 2nd option for hdd is refurbed wd
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136828
btw: sould come out at 340 or 345!
