Hey guys Im looking for a good all around motherboard with a AM3+ chipset (i will be using a AMD 8350FX)
also preferably it would have PCI 3.0 support.
I have looked and so far the best one Ive found the Sabertooth 990Fx (unsure weather it has PCI 3.0 support)
could you guys recommend some good choices.
So if I'm not mistaken AM3+ motherboards do not support PCIE 3.0. But that really won't hurt your FPS by any stretch of the imagination. But for the Sabertooth 990Fx that is a fine motherboard for overclocking or just stock clocks.
If memory serves me right the Sabretooth Gen3 R2.0 is the one that supports PCI-E 3.0 for am3+ but it doesn't work till a bios update is released. That was a long time ago i heard about im not sure if it works now. Sabretooth is great if your gonna do some overclocking but if your going for stock settings Asrock 970 extreme 3 series budget board or Asus M5A97 R2.0 higher quality in parts. 990FX chipset is great if your going to run 2 or more video cards
Hi slipknot2k4,
Thanks for your suggestions Ive already checked out those motherboards that you sent me :)
I think ill be going with the ASRock 990FX Extreme4 Motherboard or the M5A97 R2.0
Thanks
Np heres the CPU supported for the bios version
990FX extreme 4
FX FD8350FRW8KHK 125W Piledriver 4000MHz 2200MHz 2MBx4 8MB C0 Bios Version>P1.80
M5A97 R2.0
FX-8350(FD8350FRW8KHK,4.0GHz,8C,125W,rev.C0,AM3+) Bios Version>1006
Hope either of those boards have those bios version or latest. Make sure you borrow your friends USB flash drive unless you already got one just in case. And good luck
well if you wanne go with a powerhungry 8 core cpu its not realy an good idea to cheap out on a motherboard, those 970 boards, are not realy designed for a powerhungry 8 core cpu the power delivery components are lack. unless you can find a Asus M5A97 EVO R2.0. i will make a list with decent boards for you.
- Asus crosshair V Formula Z 8+2 powerphase digi vrm
- Asus Sabertooth 990FX R2.0 8+2 powerphase digi vrm.
- Asrock 990FX Extreme 9 12+2 powerphase digi vrm
- Asrock 990FX Fatality professional 12+2 powerphase digi vrm
- Asus M5A99FX PRO R2.0 6+2 powerphase digi vrm
You will be allways good if you choose one of these boards.
