I currently have a mobo with a AM2+ socket on it. it is using the Phenom II X4 9150e
What is the best CPU upgrade for performance i can get?
Can i use the Phenom II X4 975 on an AM2+?? link --> http://pcpartpicker.com/part/amd-cpu-hdz975fbgmbox
ru blind? it says it's an am2+ or better cpu.
yes, but it's probably not worth the $$$$.
O.K.
I realise that, i just wanted to ask it here because you guys will know for sure.
just, try to do a little research yourself before posting, we just get inundated with "help me!!!! [insert obvious question here]????" posts
