Am I on the right path?
I think I’m heading for a rabbit hole…and I like it.
Since I recently switched to Linux I figured it really would be nice to have the best of both worlds, a sandbox of sorts for Windows as the master wizard calls it.
I would like to run Linux and a Windows VM with GPU pass-through.
My curent configuration is:
MBO: ASUS TUF Gaming X570 Plus WIFI
CPU: AMD Ryzen 7 3700X
CPU Cooler: Scythe Fuma 2
RAM: G.Skill Trident Z 4x8GB DDR4-3200
GPU: Gigabyte GeForce RTX 2070 SUPER
SSD1: Samsung 970 Evo Plus 500GB NVME (Linux)
SSD2: Samsung 970 Evo Plus 1TB NVME (Windows)
PSU: Corsair RM 650W
Case: Fractal Design Meshify C
NIC: 10Gbit Mellanox ConnectX-3
So as I see it I need a new motherboard to support the second GPU and my NIC. Ideally (depending on the GPU) I would boost the PSU to 1000W.
So I’m looking at (based on lvl1 videos) basically Gigabyte X570 Aorus Master. Does this make sense so far?
I’ve got an x570 aorus master as well, it’s a great board for Linux and VFIO.
AFAIK gigabyte boards are the only ones that allow you to switch the boot gpu slot in the BIOS, which makes it handy for troubleshooting without having to rip out gpu’s and switch slots when fiddling with VFIO configurations.
I’m running a 5900x, vega64 and a 6800xt, and a 750w PSU, I’m not sure 1000w is totally necessary but it would depend on what else you put in there I guess.
I’m not sure what your use-case is, but you may want to elaborate on it. You can likely get some form of VFIO pass-through with your current setup.
You don’t need a separate NIC 99% of the time unless you have some special case that you haven’t outlined.
Find some owners of that board and let them post the IOMMU groups. Never had an ASUS board, so can’t share any experience. If you are doing passthrough of GPU, NVMe SSD controller and possibly more, you want groups that allow these things.
Instead of buying a second GPU, you could also get an APU, like the Ryzen 5600G. I’d rather do that than buying a 1030 GT for 100€ (insert GPU-prices rant) “because I need a cheap GPU for the host”. And integrated graphics is plenty for non-gaming. And is way easier on the power draw,PSU requirements and available PCIe slots.
The need for a separate NIC comes because I want to have a 10Gbit nic… I am aware that 1000W is a little overkill but who knows how it’s gonna evolve in the future and then I don’t want to go out and get yet another PSU.
Use case is gaming/ moderate photo and video editing
Thats a nice idea, did not think of that, so a corresponding APU to 3700x would be Ryzen 7 4700G/5700G right?
However I would also like to have a relatively powerful GPU (6600XT or something) on the Linux side to stay in touch with Linux gaming …
btw I really need someone to tell how to multiquote on this thing lol
It is too easy for anyone to notice. Just hightlight the text with mouse that you want to quote and the forum software just gives you that nice “Quote” box. Click, done.
Depends on what your price range is and how many cores you want, but yes…the “G” instead of “X” means that’s an APU (with integrated graphics)
And as long as you are not gaming on both machines at the same time, just shutting down Windows VM should return the GPU to the host. But I’m not 100% sure on that. No need to maintain/buy two gaming-capable cards then.
Hmm, that does sound appealing if it works that way, which I’m not sure. The thing is that I have a nvidia gpu currently and as I see it it’s better to have an AMD GPU for Linux…
While possible to restore the usage of the card after using it for a VM etc, it’s not super painless or easy. You’ll get all the fiddling around of trying to do a single GPU pass-through with like none of the benefits, and you’d end up still needing to restart X, swap configs etc.
I’ve had to use my VFIO setup less and less due to how much better gaming on Linux is these days. To the point I haven’t booted it up since cyberpunk came out last year.
