Am I missing a repo in OpenSUSE?
Recently I used zypper to remove a repo conflicting with the installation of packages. By chance I for what ever reason did not use YaST and as such I typed "sudo zypper rr 2". It doesnt appear as if anything is missing however I'm not sure. I wiil post the output of "sudo zypper lr";
# | Alias                              | Name                               | Enabled | Refresh
1 | download.opensuse.org-13.1-non-oss | Update Repository (Non-Oss)        | Yes     | Yes
2 | download.opensuse.org-oss          | Main Repository (DEBUG)            | Yes     | Yes
3 | download.opensuse.org-oss_1        | Main Repository (OSS)              | Yes     | Yes
4 | download.opensuse.org-oss_2        | Main Repository (Sources)          | Yes     | Yes
5 | download.opensuse.org-update       | Update Repository (DEBUG)          | Yes     | Yes
6 | download.opensuse.org-update_1     | Main Update Repository             | Yes     | Yes
7 | openSUSE-13.1-1.10                 | openSUSE-13.1-1.10                 | Yes     | Yes
8 | repo-debug-update-non-oss          | openSUSE-13.1-Update-Debug-Non-Oss | No      | Yes
 Shouldn't there be nine repos...
Anyone?
https://en.opensuse.org/Package_repositories
I haven't used SUSE for a while but there's usually 4 official repos as default on a vanilla install, and then whatever community based repos you choose to add, like packman for codecs etc etc.
Thanks. I tried upgrading to tumbleweed, but GTK versions got mixed up... Tomorrow I'll try downgrading with my full iso. From there I'll try reinstalling tumbleweed. Factory actually looks appealing seeing as the final release of 13.2 is only in 23 days (as of now).
personally I would use Factory over Tumbleweed, it would appear Factory is set to replace tumbleweed
Tried updating to tumbleweed and gnome broke. I downgraded back to stock and now I have text blocks instead of text. I'm fed up with Gnome. The transition from Gnome 2 to 3 was the worst ever. I would use Mate however it doesn't implement new technologies. You know what? I want to make my own damn DE.
