Am I insane?
I recently installed Ubuntu alongside windows, as im trying to be more dependent on Ubuntu instead of windows. But I was wondering, why does it run so slow, slower then windows. I just built this rig less then a month ago, so not hardware issue I believe.
Like it's not happy when i to try to run Firefox and an installer at the same time or run a game and play music at the same time or one app will freeze blah blah vlah.
Any tweaks i can make, or services I can turn off to increase performance? I just don't know whats going on.
without reading the rest of your post.... yes, you are insane if you must ask .
Step 1. Delete windows.
Step 2. Delete Ubuntu.
Step 3. Install something Linux that isn't Ubuntu.
Honestly the only way.
Might be Flash player, it's an absurdly resource intensive application on linux. It's so absurd compared to Windows that people outright call it Adobe sabotaging linux.
And do yourself a favor, move to another distribution. I did and it's the best thing I ever did. People seem to like Manjaro, because it's bleeding edge, so you'll get the latest kernel, driver support and applications, it has Steam integrated out of the box, and a lot of other applications installed out of the box. And you can install all the Arch Linux and AUR (ArchLinux User Repository) packages.
I haven't tried Manjaro, but the people recommending it (mostly Zoltan and brennanriddell here and there, to be honest) do look credible (to me).
okay if you must do this setup style dont use the .exe ubuntu its crap, to be fair ubuntu is crap, go manjaro, ditch Windows and live a free life.
the side installer for ubuntu has always been awful even says on the website i believe that you will experience slower performance than bare metal install.
go Manjaro, Sabayon or Fedora, experience what security, speed and been the most updated person feels like ;)
If you did a WUBI install, then you did it wrong. Get rid of Windows and go with the Linux distro of your choice.
Actually, Brennan uses Arch, whilst Zoltan uses Fedora.
I am dissapointed with this post as I thought it had something to do with you thinking you might have gone mental...
same here..
nice guys...
Thanks for the info I haven't heard of that distro, though still new to this. I'll give it a try.
Zoltan has some great posts on this subject; Phantom said it well, though - use something other than the *buntus. Architecturally and at a corporate level, Canonical is kind of against the Unix philosophy- they try to make everything do too much, and do it for Ubuntu, not anything else. A bleeding edge distro is the only kind worth using on the desktop, now - the updates are pushed when the software is updated, not when Canonical has "tested" it, only to push it, have a security hole, and not fix it for 6 months, until the new version of Ubuntu is released.
There is no reason to have Windows installed bare-bones. With virtualization and compilation layers, most Windows applications can be run on a Linux system more efficiently, due to advances in Dx to GL call conversion, plus the added security of Linux being in the background (running C++ much better than Windows can dream of), rather than Microsoft's antiquated, security hole-filled, NSA spied-on crap.
Fedora is a great place to move on to - it will be a distro you don't ever "outgrow" like Ubuntu.
Well i've been looking at switching to a linux based OS for some time but couldn't decide. Basicly i want somthing that is widely compatable with software out there wirte'in for it, i know i can use wine to run my windows programs, but i mean like witch distro would have more applications that where writin for that distro, like Fedora, manjaro, ect. or the most widely used.
With very few exceptions (nothing I can even think of), all Linux software runs the same on all Linux distros.
As far as software easily available from the repositories, Fedora is probably the best.
Truth.
Check out Korora.
I wasn't saying that they are using it themselves (or that they aren't, for that matter), but that they recommend Manjaro as an introduction to the linux world :)
Instead of talking nonsense, I'm just going to point you to Zoltan's solution to your problem: Virtualising Windows under Linux (preferably Manjaro, he says) utilising the kernel virtual machine module
Ah yes, Linux being faster. I've only experienced that when I used something but Ubuntu. I still remember when Debian 5 ran more or less fine on my old 900MHz/154MB RAM/POWERPC laptop. And it was still more responsive than Windows on a machine that is 5 times as fast.
Installing linux next to Windows is just wrong, for some many reasons:
1. Windows wastes the fastest part of a HDD on useless files that you probably will never need, restore files, CAB files, etc... that's just crazy
2. Windows can only be installed natively on NTFS or FAT, which is another waste, because it's a wasteful archaic retarded filesystem, and if you install linux on the same HDD, it will also suffer from that retarded filesystem, and it will probably be installed on the slowest part of the HDD, at the end
3. If you used WUBI, congratulations, you've just screwed up your system, you might not see it yet, but it's seriously screwed. There are more elegant ways than WUBI to screw up your system
4. You cannot use Windows and linux at the same time, that means that - unless you have great discipline and patience - you'll continue using Windows for most things, and the return on investment of spending time installing linux will probably be very minimal, but sometimes you don't have a choice, in particular if you're a Windows gamer and don't have an IOMMU capable system
The best solution by far, is to buy a cheap SSD (they are what, 60 bucks now for an LMC 128 GB one?) and install Linux on that, only linux, an easy-to-use distro (and that really means easy-to-use, not "one size fits all" like Ubuntu, there is a difference, grabbing a hamburger at McDonalds may seem easy, but a hamburger is not easier to eat than a salad, it's just easier to choose, because you only need to make a decision between one with and one without cheese, that's exactly what Ubuntu does, they try to make choice easier for you by taking it away from you, that's why I call it a McDonalds-distro, and Mint is in the same category.)
If you want to keep your Windows install, great, it doesn't change that, GRUB will automatically identify the Windows install and offer it at bootup in the menu.
Easy to use high performance distros are community respins of high performance bleeding edge distros that offer more than a minimal iso, they offer a GUI installer and a lot of preinstalled software to make life easier. These are not "beginners" distros, they are distros that are "ready out of the box" or "easy to use".
If you don't ever want to use the CLI, what I recommend is OpenSuSE. It really is the only distro that I know that will allow you to use every part and every function without ever using a terminal command line, and that has everything to do with Yast, which is a great tool that does everything.
If you want bleeding edge and the latest and greatest (and oh boy you're in for a surpise if you've only used Windows and the see what's possible in linux!), go for Manjaro, which is Arch based, or for Sabayon, which is Gentoo based. Arch is a tad easier, because of the AUR, the Arch User Repositories, where you can find the biggest collection of prepackaged software in the linux world bar none. You'll have access to the same amount of software in Gentoo or Fedora, but you'll have to install it from source sometimes, which is a bit safer, but also a bit slower and sometimes a bit more technical if you for instance have to compile from git, but especially as a beginner, the odds of needing that are incredibly slim. I don't remember the exact applications count in the RPM repos, but I think there at over 46000 applications, all free and open source, and that's a lot. Gentoo and Fedora do have the advantage of being able to use different package managers from different distros, without screwing up the system, because they're all RPM-based distros, like OpenSuSE, Mageia, Rosa, OpenMandriva, etc... and Gentoo and Fedora specifically also compile from source automatically with their standard package managers, whereby the focus of Gentoo is on source and the focus of Fedora is more on binary, but in fact, they're both source/binary distros.
If you want to make a job out of linux, you want to learn multiple distros, you need to learn Fedora/CentOS/RHEL (those are all pretty much the same, but Fedora is the upstream, so it's best to learn that one) and Debian for sure, those are the distros that literally make the world turn. If they would disappear, the world would literally cease to function, there would be no power, no cars, no water, no electricity, no medical care, no traffic management, no air traffic, no satellites, no advanced weapons systems, no Internet, etc...
Fedora is pretty easy to use, it has a GUI installer (that is also used by Sabayon, it's a very nice installer called Anaconda, and I wish Manjaro would start using it, because it's nicer than the installer they've made themselves), it has a selection of preinstalled software, but it's all pretty vanilla. You can immediately configure your system with a third party tool called Fedora Utils (it's officially third party, but the developer is a Fedora dev, and it simply can't be in the repos because it also allows to install proprietary graphics drivers and non-free codecs and software).
I could use Fedora, Sabayon or Manjaro, it would make very little difference to me. I wouldn't want to do an Arch or Gentoo install from scratch because it would take more time, and Manjaro and Sabayon are very close to Arch and Gentoo and make configuration a lot easier. I mostly use Fedora because I like some of the unique Fedora tools (DeltaRPM/Presto for less download volume when updating, gains a lot of time and bandwidth, FedUp to do version upgrades to have a fresh system every six months without hassle, which I prefer over a rolling release, yum as package manager, because it has incredible features and I like it more than pacman or portage), and because I run RHEL boxes in my companies.
Thank you for that detailed response. It sounds like fedora may be a good pick, basically I want, something replace windows completely soon, it's quick to install, and it's somewhat user friendly but I'm still able to configure it down to how it runs if i really wanted to.
I've been on windows since 95, and it was my choice of OS because it was everywhere and was easy to use. But as each release came I became more frustrated with all their updates the $140 for a full version, some security holes, the resources it hogs. I'd usually dump my pc once every about year and a half and do a clean install just so all the useless files where gone.
I'm willing to learn the ways of the terminal. Thanks for the incite.
