Pretty much what the title says, I have a 750W PSU and a 7600X and the intention is to piecemeal upgrade my AM5 foundation over the next few years, unfortunately my gtx770 is on its last legs, the (frankly shitty barely acceptable nvidia driver under linux) driver drives me insane on a regular basis and a lot of the games and emu I would like to run are sluggish at best and bad at worst… So its time for a new GPU now.
nvidia I basically blanketly toss aside this time because of the excessive amounts of heartfelt 'fuck you’s, arrogant apple-like rhetoric and toxic behavior towards- and poisoning the community at large.
Which leaves me with amd or intel, but I dont really feel comfortable spending money on the state the intel gpus are in at this moment.
Which leaves me with just amd.
Im expecting power bills(in europe) to rise due to the world being a progressively more and more awful place to live in, so efficiancy is kind of a consideration here.
Looking at future I do would like AV1 encode and some amount of competent AI acceleration, but I dont really care about ray tracing at all. Which excludes basically everything RX <= 6XXX
Looking at the 7900XTs available to me the cheapest partner model you’d actually want to buy is 930€ and usually come with a 750W PSU recommendation.
Looking at the 7900XTX it would be 1100€ and they usually recommend a 850W PSU.
7800s and lower are due to release eventually™ but I kinda need the GPU now and I have waited for arguably too long already and the conventional wisdom is you should buy what you need when you need it.
Checking out reviews I notice a scathing difference between the xt and the xtx in terms of performance. At the price range an increase of 170€ isnt too much and the performance gain is admirable, so Im leaning towards that right now. Im expecting to get about 10 years out of the gpu so Im okay with spending a little more. According to Gamers nexus the average full load power draw of the xtx is ~350W with the highest observed transience at 192%. Adjusting the average wattage with 2x accordingly gets me to 700W worst case, which is… close?
Im not really experienced in PSUs and power, is this flying a bit too close to the sun or is that perfectly fine and doable?
My psu is a Seasonic prime titanium 750W which are generally considered to be very good quality PSUs from what I read and I know that high quality PSUs tend to resist transient spikes better.
(also how is the underclocking/undervolting experience on linux for the xtx? part of my rationale for going for the highest quality dye is that in theory better silicon ‘fitness’ will give me more headroom to go down with power while maintaining good performance thus upping the efficiency, any experience on that front?)
Im gonna read all that in a minute but
People think they need more CPU than they actually need, especially if you run 1440p or higher or if you don’t intend on going above 60fps
I would actually go with a 7600 non-x if it’s cheaper by any bit
If you’re already on AM4 id consider just getting 5800x3D
The AM5 board, psu and 7600x I already have ![]()
Its more of a question of whether or not a 7900xtx would fit into my power budget.
Yes. I got the 7600x for exactly that reason, due to living in the EU they were the exact same price when I did the upgrade to AM5. I intend 1440p at 60 maybe 120 or 144hz since afaik those are the points of diminishing returns
I think you’ll be just fine with the 750w depending on the age of the PSU and how much it degraded
Your 7600x would have to use about as much as the 7900 xtx both o overload it and that’s 3x it’s stock tdp
A new PSU might be in your future but for now I think you’ll be fine
Keep vsync on, they turn that off for reviews, that’ll help with power consumption
Should be fine ![]()
Thats reassuring, thanks!
Any resources on undervolting/underclocking on rx7000 that could be helpful to me?
i havent tried it, but ive heard good things
For the power draw of a system, I generally count like this:
- 50-100W for fans, drives and other bells-and-whistles
- 7600X draws up to 170W - that is the max of the socket
- 7900 XTX can draw a total of 375W (75W from MB + 150W per each 8 pin cable) - that is the maximum the platform supports before heading into OC territory
So in total we’re talking 100+170+375 for a total of 645W, worst case, with an average load of perhaps 300W-400W and an idle load of somewhere around 70-80W.
750W should be fine.
I did a bit more reading and found a number of reports or coil whine on the 7900 is that something that people have experience with? Is it just the reference designs or specific to a partner model?
I also read that a funny 12v rail can cause it when the psu is aging/using bad quality component or overloaded, is that a thing to be aware of?
In general the GPU will drain about 350W, so you should have more than enough for the rest.
I would have gone for 850W if I could, just for the efficiency curve, but 750 shouldn’t cause any issues if it’s a good brand and high quality.
This is literally a card issue. It depends on the specific card, altho with the automated manufacturing nowadays some models may be more prone to it than others…
In general coil whine is a specific card issue if I am not mistaken…
yes? If the PSU is low quality badly made it can cause issue, yes.
You should have absolutely no issues with this one…
very well, thank you!
The inductors with the best electrical characteristics seem to be the ones with the worst audio characteristics ![]()
I guess there could be weird interactions between having two DC-DC converters linked together. Anyone want to sponsor me locking in my room for a year while I dive into it? ![]()
Well I like to overkill my PSU.
I have 1300 watt gold evga powering 5950x and asrock 6950xt…
I have seen my video card use over 370 watts, so at a spike that is 740 watts for the little bit.
I wouldn’t go any less the 1000 PSU myself.
But I overkill my PSU all the time.
I actually swapped out a 750 in this rig for the 1300.
Depends on your model. I have quiet mode on mine. No complaints. I havent tried turbo mode yet.
I think a higher wattage can protect your system from transient spike in power comsumption.
Funny things can happen if there is a sudden high demand in power. You might get system instability, random hangs, etc.
But if you promise not to stress your system, I think you can get away with it safely.
I’ve been looking at the cybernetics test report and the PSU remains stable and operational within the 110% range which is about 820W which is good enough for a worst case for me. (Im in europe so 230v for me)
And the only way it can even possibly get that close is for a couple of for a very short time during a transient spike with the cpu absolutely maxed. I think I’ll be fine
Guess not cheaping out really does pay off
