Hi all, I recently purchased a Logitech MX master mouse. I really like it so far, but the feet on the bottom of it creates too much friction with my mouse pad. Currently I'm using the smaller size TekSyndicate mouse pad, and was wondering if an aluminum one would have less friction without any loss in accuracy. Also, would the aluminum wear the feet down in any noticeable way? Thanks in advance
Chuck
Why would you want to get an overpriced piece of aluminum?
The fabric pads from Razer are nice.
What kind of mouse pad do you prefer or, what kind of mouse pad is your mouse optimal for? Cloth or hard surface?
he's just asking if there is a performance benefit
OP it depends on the roughness of the surface
Al can track good, depend on variety of factors as usual
Thank you for understanding the question and posting a relevant response :)
I found a couple on amazon for around $12 each. I think I'll just buy one and see how it is, if it's a bad mousepad it can maybe be a good coaster or something
A mod can close this thread now
