Well i'm building my pc said this a thousand times because i can't make of my mind, but i have a task for you people to put together the most sexy build you can think of with this budget without losing much (if at all) any of it's power. Here is the base build http://pcpartpicker.com/p/1m9JC i would love to see what you can guys come up with, Also you don't have to worry that much about making it cheaper. Go as over the top with this build if you want change it as much as you want i want to see what you think would looks good. max budget is 2650 including monitor, keyboard ect....
http://pcpartpicker.com/p/1n0Cj
slightly over budget, but it does include an i7 4770K ;)
Try this http://pcpartpicker.com/p/1n0Lb
