Hello,
I wa slooking at getting a mechanicla keyboard (ducky 1087) that has black or Green ALPS Switches. I was wondering if they're any good or should I avoid them? Pretty much looking for any feedback on them.
Cheers
Hello,
Cheers
ALPS are pretty cheap switches, that are very similar to linear MX switches, like the Black and Red, but are still superior to membrane switches.
ok thanks for the help. It's about $30 more for getting a cherry mx switch. Would you recommend I just go for a Cherry MX switch?
Heres a $50 mx black keyboard
http://www.thermaltakeusa.com/store/Product.aspx?C=1154&SC=1165&ID=2022
thermaltake makes good keyboards, its $40 off on clearance now, get it now
$22 shipping to Canada :(. thanks though, Ill look around for that one
