So im planning to upgrade my old "router" and i stumbled upon the ALIX 2D13.
Is there a WLAN mini PCI card, that you could recommend? I looked at amazon,
but wasn't "pleased" with the info, so please tell me what to use and what not.
Is the ALIX a good router in general, or should i go with something else like a liksys?
As a reciever I'm using a Asus PCE - AC 68 (probably overkill, but 'hey').
Thanks in advance, Max
Links to Hardware:
ALIX : http://www.amazon.de/dp/B004ZPXOYK
AC68 : http://www.amazon.de/dp/B00EC9S3LI
