Hi.
Currently having a dilemma regarding adequate airflow in my case for planned changes/upgrades...and I can't quite figure out what to do.
Currently, in my Fractal Design Define R4 i have 2x140mm 1000rpm intake fans (where the lower fan blows onto the HDD cage and the upper fan directly into the case as the upper cage is removed), the same as a top exhaust and push/pull noctua NF-F12's (120mm PWM) on the rear as intakes on a Corsair H80 radiator.
For reasons i won't go into i plan to swap out the H80 for an air cooler (be quiet Dark Rock Pro 3), switch the exhaust to the rear and blank off the top...and planning to replace current lynnfield based system with a haswell-E, GTX980 (when it's for sale) and also run my current 750Ti...
I have a feeling the 2 front intake and 1 exhaust won't be enough airflow, especially intake to keep the system cool when using an aircooler and having GPU heat dumped into the case too (especially low RPM quiet fans...because i have an obsession with quiet).
I was thinking I'd fit my spare 140mm fan as a bottom intake...except my PSU (be quiet dark power pro 10, yes i like their gear!) is 180mm long and a 140mm won't fit and a 120mm is also out of the question due to where the CPU 8 pin power connector plugs into the PSU...
So i'm completely out of ideas of what to do and would happily look at any suggestions anybody might have (apart from staying with an AIO WC and not getting an air cooler)...or if my 2 intakes and 1 exhaust might be adequate? (in the summer small room with a lot of electronics = oven).
Thanks in advance for any comments or suggestions. :)
*edit* a crazy solution would be to get a seasonic gold or platinum psu or a corsair AXi which are all 160mm long and have modular connectors in more sensibly positions...but that'd be a bit of a drastic solution and a rather expensive one, too!
