I have been using a overclocking/sytem monitering software called ai suite 2 and i belive that the temperature sensor for my cpu is not telling me the correct temps. I was wondering if there was a way to recalibrate or fix this issue.
i think the temperatures that this program is giving me are wrong because i used core temp and realtemp to compair and they show the same temps, AI suite 2 was off about 20 degrees C
-pc specs are on profile
Last time I installed AI Suite II, it killed my Windows installation. Thing froze before login.
Not going to use any software from Asus ever again.
so the software is just Garbage?
Well, it may work but it's so slow and unstable, I'd rather use BIOS and alternatives for everything useful that it does.
Do you know of another fan controller that is software?
I'd personally set up fan profiles in BIOS instead of controlling them.
There's SpeedFan but I'm not sure how it works.
