I’m torn between buying new tech (which I probably don’t need) or optimizing what I already own—maybe even having leftover funds for something small. Here’s my dilemma:
The Laptop Temptation
Initially, I was set on the Flow 13 (128GB RAM—yes, please!), but it’s nearly impossible to get in the UK. Next up: the HP G14a. I’ve hovered over the buy button multiple times.
Why? The idea of that much ram for LLMs in such a small package blew my mind, and I figured it could double as a work machine. (Currently on a Ryzen Asus G14/4060, which I’d sell if I upgraded—though part of me wonders if I should keep it for video editing but I also have a 4080 strix laptop as well, not sure if I should just make this my new work machine.)
But… Without a dGPU, the HP might struggle with ComfyUI, SD, etc. So then I thought: What if I skip the laptop and build a dedicated 5090 AI server? Pricey, but powerful.
What I Already Have
- Main rig: 5090 + 96GB RAM (used for ComfyUI/gaming—though gaming doesn’t need that power).
- Second home:
- Unraid server (4070 Super) running Ollama + Plex transcoding plus a few other things (could swap back to the old 1660).
- Desktop with a 3080 (gaming rig there).
- Another laptop: Strix 4080.
The Real Question
Should I:
- Forget the Strix Halo laptop and repurpose my 5090 into an AI server, using the 4070 Super as my new gaming GPU?
- **Say F it and buy the laptop
3.**Build the AI server, buy another 13/14 inch laptop with good battery and sell the other laptops?
If I go the AI server route, what else would I need? Ideally, I’d like it to be compact—but is that even feasible with an MSI 5090? Intel or AMD CPU, thinking Intel to max out the RAM slots? Windows or Linux?
Would love advice on how to streamline this or recommendations on the best path forward.
Edit with some more info:
Unraid Specs:
i9-12900
48 gigs of RAM
4070 Super
Desktop Pc at same home as Unraid Server:
i7-11700
RAM: 32.0 GB
NVIDIA GeForce RTX 3080
Main PC at other home:
AMD Ryzen 5 7600X
96.0GB RAM
RTX 5090
Asus G14 Laptop:
7735HS
32GB RAM
RTX 4060
Asus ROG Strix G16:
13650HX
32GB RAM
RTX 4080
