So I built my first computer and everything went well... and I wanted to say thank you to all who gave me advice.
So after I built my computer the USB 3.0 ports on the back panel stopped working and I am about to send it back for a replacement. I have been using the stock heatsink that came with my FX-6300 and it has been working well... i have had no problems, but beacuse I have to take the the heatsink off and I will have to buy thermal paste (about $10) do I spend alittle more to get a aftermarket heatsink that comes with thermal paste?
I found a heatsink on newegg for $20 after a rebate
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible with Intel 1366/1155/775 and AMD FM1/FM2/AM3+
It looks like it should work with my MSI 990xa-gd55 motherboard.
Is this the way to go or should I stick with the stock fan or get another aftermarket heatsink?
Also I need to make sure that it will fit with the rest of my system.
Corsair 400R, MSI 990XA-GD55, FX-6300, 16 GB G.Skill Ripjaws X 2133 (4x4GB), ASUS GTX-660)
I dont want to spend alot on a heatsink fan I would be willing to spend $30 max.
