After much debate... My new final $1500 build (hopefully)
Suggestion and Opinions are welcome as well as needed! Thanks!
The complete list: http://pcpartpicker.com/p/2cyqC
I orginally was going for an AMD build but after much research,debate, and endless hours i have come to this intel build seeing as the CPU is far better than my original AMD build and IMO the gpu being also better then AMD's new series.
Old AMD build: http://pcpartpicker.com/user/atomicfire7/saved/30eh
IMO the intel build surpasses this old AMD build, input would be great, as i am unsure of the motherboard going with my intel build.
I'm not sure how you came to the conclusion that your intel build is better than your AMD build, I would consider the 8350 to be better than the 3570k, the 3570k will be better at some things but overall the 8350 will be better.
Also, the 280X is a better GPU than the 770, not by a long shot but look at benchmarks just about anywhere, and you will see that it outperforms the 770 significantly more than vice versa.
Ya im going for the 780 now (having found cheaper RAM) also i looked at the benchmarks for the CPU's and the intel seemed far better and cost effective, I am not sure as i am a novice, but are most games tailored to intel and GeForce right?
http://pcpartpicker.com/p/2cyYl
no the new gen of games is going way more amd i have a FX-8350 and 270x its great
That looks like a solid system except maybe the motherboard. It looks really cheap. Read into what users are saying on various forums about the combo.
I just deleted 3 other topics from you about the same build question. There is totaly no need for starting a new thread everytime, wenn you come up with a new build. Just modify your existing topic next time please. You probably  a bit new into forums so to make it easier this time i will lock you other active thread.
https://teksyndicate.com/forum/build-pc/my-amd-build-around-1500-did-i-do-good/162335
Please next time, be ware not to post new topic´s over and over again,wenn you got some new build idea´s, just modify your startpost.
Grtz Angel ☺
your amd build is a way better in overall performance, the only thing you had to change like i said in your previous topic, just trow in a GTX780.
Ya thanks, i ended up with this build: http://pcpartpicker.com/p/2cC51 I think this is a beastly build and money is not an issue as i am now getting support from a relative.
P.S. Ya i am new to forumns and you can delete those old threads and ill stick to one next time! Sorry
Looks good ☺
good balanced build have fun. :)
